Music Narrow Widget has following Features:
- Two Views: One with Cover Pic and another Without Cover Pic. Tap on left side of the widget to switch between two views.
- Tapping on middle part of the widget will take you to music app.
- Music info is parsed using (a) Tasker Profile - uploaded here or (b) KWGT in built variables. You can choose which source you want in the Global Vars section of the widget.
- Use the buttons on the right side to control playback
Check here: GitHub - rjwarrier/KWGT-Widgets
