I’ve created a few Widgets but now cant save them as zip files, only as a normal file. That means I can’t move the ones I created or make new ones because I have no more space I need to be able to save as a zip file so I can come back to get the widgets when I want.
Can anyone help me? Thank you
I think there is no zip conversation available in kwgt. Try exporting your presets and save them in a folder of your choice and compress whole folder and save that zip file. I think this way can be helpful as I used to do this way exporting presents and saving them in a place.
Zip is not supported, a widget file is ALREADY an archive (rename it to .zip & you’ll be able to see the files within). Why don’t you just backup the .kwgt files?
