New Widgets. There are two Weather Widgets. One shows Temp Info while the other show Temp Forecasts based on interval you can set in Globals. Almost all values I have set in Globals so that you can change easily.
The Battery Graph shows battery level history based on interval you can set. There are buttons in the bottom half (invincible) by which you can easily change the interval.
Please check and post your opinions!
Github: GitHub - rjwarrier/KWGT-Widgets
(Check the Folders for new Widgets)
